has anyone experience in manipulating incoming MIDI-Data before handing it over to another application in Win10?
I use a Win10 machine for MultiRack SoundGrid. Unfortunately there’s no IP-MIDI Driver for Windows only for Mac. I’d love to use a mac, but the band wanted it with Touchscreen for guest engineers. So Mac and f.e. touchbase isn’t an alternative, as the 19" is already there …
My idea: there is a A&H Driver for DAW Control. If I can manipulate the data (let’s say Level CH1 0-127 changed to PGM-Change 0-127) and than hand it over to MultiRack SoundGrid it could work. But I’m no MIDI-Crack on PC, so I don’t know the Tools (if any) and how to handle them. So I’s Programm a MIDI-Fader in dLive sending Midi-Values corresponding to scences (I don’t need more than 100 Scenes)
I need a tool, that reads data from the virtual DAW-Control-Port from A&H Driver (Midi-over-IP), changes them and sends it to another virtual MIDI-Port, that could be use in MultiRack SoundGrid as Midi-In.
Midi-Ox will convert data for you. Might be tricky to install in windoze 10 but I believe it can be installed. Also Midi yoke or loopbe for virtual (internal) midi ports.
@Steffen:
did you manage to make it work? I tried rtpMIDI with no success. Documentation of GLD and iLive says, that they use Port 51325 for connection, so I tried to make a connection with the dLive Surface (192.168.1.71:51325) and Mixrack (192.168.1.70:51325) but both failed, rtpMIDI could’t establish a connection.
@Stix: nepp I found Midi-Ox after I posted here. But till know I couldn’t manage to convert the Data. I see incoming Data in the Midi-Monitor, but if I move Faders from Channels it seems if I get the same data (a Note on, off which seems to be the Fader-sense, then Pitchbend with different Data-Bytes regarding Fadermovemaent, then again a Note on/off, but the Note is always the same. I’d expect different Notes for different Faders).
If I make a Midi-Fader in dLive (where you can program custom Midi-Data) it’s not seen in Windows as the DAW-Driver seems only passing Data regarding HUI or Mackie Control, nothing else,
from another of your posts you state the mac option, using the A&H TCP midi driver works for your needs, while i’ve not done it the way you ask i’ve sent midi program changes over ip to several computers using ip midi….another way to do this, without the need to translate /interpret midi msgs, would be to use your mac as a front-end for sending the program changes (i.e. scene changes in Dlive + preset recalls in Soundgrid)…… I use Qlab regularly for that very purpose……sort of a central midi program remote……You could probably also use the mac and ip-midi as a go between (dlive >mac>pc)
Short and clear: Mac works with A&H Driver, Windows doesn’t. No driver so far from A&H and rtpMIDI and so on didn’t work - or at least I couldn’t make it work.
As it’s a touring setup from a band it has to be totally fool-safe and independent of my personal stuff, so using my own Mac as “midi-translator” is no option. When I’m not there, it won’t work then.
With 1.5 (and later) it’s NOW possible under Windows to do Midi PGM (f.e. To use with MultiRack).
With the Windoes DAW Controller Driver there’s a “Thru” mode in Windows (like HUI, Mackie Control). With this, MIDI is passed thru (there PGM Change is sent with Scene Recall).
It’s not easy to find, so I thought I’d share as it took me quite a bit to find it!
I know I’m late to the party and someone new to the technology, however can we use MIDI over Ethernet for a windows environment or not?
I have a simple setup for stage…
iPad using Onsong for…(Lyrics, Changing Patches on Boss RC-300, Starting Backing tracks on Windows laptop with Ableton Live, and Changing Patches on Line 6 Helix for my guitar(s).
Laptop using Ableton Live for… (Playing through USB multi-track audio to the QU-16.
That being said I would like to
Send simple midi commands from Laptop(Ableton) to the QU-16 to mute, unmute & maybe adjust volume.
Send Midi to another a TC-Helecon VoiceLive Rack Harmonizer in which I wound select a patch, and even control key’s and such for harmony’s.
Be Gentle… New guy to the tech…
I’d like to spend more time playing than configuring.
