Mirroring Main Mix to Aux
Setting up an SQ-6 here. I must be missing something. Is there a way to take my main mix and send it to an Aux. I am trying to do the following:
  1. Assign a few levels from my main (kick drum, bass, etc.) to go the subwoofer in Aux 1. Is there a way to bring it up in both by just using the channel fader in the mains? Would I still be able to fine tune it in the Aux 1 mix?
  2. This is probably easier, but I’d like to take the mix going to the main house mix, and have Aux 2 (our lobby) mirror whatever the levels going on in the main.
Any thoughts on how I can do these?
1 - Make mix1 pre fade, and put sends at unity. Mix1 will get whatever level you send to L&R and you can adjust the send faders to tweak the amount going to subs.
2 - send L&R to a Matrix and use that ( though for the moment, matrix are only able to be stereo)
Thanks! That set me on track!
GREAT and very sensible tips Mark!
Since I run the sound for two of my bands - from the stage… and use in-ears in one of them, I think I’ll use this next time we rehearse and try it out!
should the send for subwoofer not be POST fader?
Yes!
Sorry. Fingers not connected to brain - or something.
…aaaaand I’m back. Got the subs figured out, but I’m still having a hard time with mirroring the main mix to our lobby (aux 2)
I’ve got the main LR sending to Matrix 2, and I’m getting signal through Matrix 2 and can hear it on the PAFL, just can’t figure out how to get it into the lobby.
I should also note, we want the main mix mirrored during services, but in the morning while the team is rehearsing, we want the mp3 player to be the only thing going out there.
Do I need to map the matrix to an input? I’m stumped here.
input to matrix is not possible at the moment
so you have to spent an bus to send the mp3 to the matrix only, and not to the main mix
your signal flow:
mp3 input > bus > matrix
microphones > main mix
during showtime you change this to:
mp3 input > main mix
main mix > matrix
the matrix is the only signal what goes to the lobby
you have to adress the outputs you are using for the lobby with the matrix signal
this is done in the output patch screen
