Is there a way to mass assign/unassign everything to a selected mix/mtx/group/main buss?
It’s rather tedious having to unassign all my inputs that I want to group, out of the main bus, etc.
Hi Senny,
If you have the Mix selected, then hold assign and press the Mix key for the Mix, it will toggle everything/nothing selected.
Jack
I usually do it via the routing tab, it’s the fastest way (and helps to make sure you haven’t accidentally assigned the same channel to multiple groups etc)… this is a great visual way of doing it, especially now there’s all the extra routing possibilities in 1.7
Salut Biggsound, what is your combination of Buttons/Keys you are pressing to reach what you are describing.
How about holding the reset button and pressing the mix button?
