Mix Bus Not Passing Audio
Hi All,
Encountering an issue where occasionally no audio passes through a mix bus, most commonly (but not limited to) the first mix bus in the config (Mono Group 1). This happens from the moment the console turns on until intervened.
We have had this issue 4 times now. Two of these times restarting the console and recalling the same show file corrected the issue. One of these times recalling a different show file (saved from a day or so earlier) and then recalling the correct file resolved the issue. The fourth time neither of these worked, nor a reset of both the surface and mix rack across the two show files. A new show file was built and it working.
I guess you have an issue with the old showfile and a scene.
I had similar issues in the past, but could nail all the issues down to faulty patching or inserts enabled without the right signal path being available.
