Do you know that moment when you’re adjusting the faders for your main LR mix, only to realize after a few adjustments that one of the monitor mixes was still selected?
It happens to me more often than I’d like to admit.
I think it would be great if the Mix and FX buttons could optionally be configured to work like the Talkback button, with two different behaviours:
Short press: switch to the selected Mix and keep it selected.
Press and hold: switch to the selected Mix temporarily, and automatically switch back to LR when the button is released.
This would make it much harder to accidentally adjust a monitor mix when you intended to adjust the main LR mix.
The CH TO ALL MIX button already demonstrates a similar momentary behaviour, so perhaps this could be implemented for the Mix buttons as an additional option.
This would be a small feature, but a very useful one for live operation!
I am certain that most people who deny this are lying.
Even if they work with the console daily and the workflows have truly become second nature to them, they should still clearly remember their own early days.
A clearer indication and better handling of SOF mode - including your sensible suggestion - have been on the SQ wish list for years, with plenty of votes.
Yet, this simple modification didn’t even make it into the new SQ+ series.
A&H simply knows much better what is necessary and what is good enough for their customers …
Having used QU and SQ desks in many varied situations, almost since the introduction of each range, I can agree that you never quite stop forgetting to return to main LR after altering an aux mix! It is something I have got used to, and learnt to spot my errors very quickly, but that is not ideal, and I agree with you that some form of momentary selection would be great.
A very simple but effective possibility to reduce this kind of fault, i agree.
During waiting for a update with this feature, here is what i do at the moment:
1 - I set the softkey no 8 on my Qu5 (in best position in the lower rhight corner) to ‘Mix Select Main LR’. The original ‘LR’ button is placed a bit lost / unobtrusive.
2 - I have a set of flat (2-3mm) strong magnets. I mark them with colored waterproof pens and put them next to the softkey to recognise the function in no time and - for the softkeys with ‘Mute Group’ funktions - i place the magnets left and right against accidently pressing them.
Of course, the second press on a Mix-button is a nice solution to go back to the main mix, but if you stay in a monitor mix by accident, it can really ruin your day. So 99% security isn’t enough…
