Mix control for the parallel path processing
Hi, if possible it would be very useful. especially for a live use, the MIX option in the Parallel Path of the dynamic processor in addition to the already existing option
of the independent DRY and WET controls.
So that it is possible to directly manage the quantity of mix between the dry and the wet signal through a single control.
For example 50% indicates half signal dry and half signal wet.
But in this case it should depend on the dry and wet settings (from the base ratio given as the difference between the two signal levels).
This allows you to adjust the basic settings given by the mix between dry and wet on a percentage scale, helping the mixing engineer to be able to simultaneously adjust the two parameters,
since if I change one parameter at a time during the live, you can hear the variations of gain on the two signal levels, while what should be perceived is a dynamic variation.
