Mix & LR volume level
Hello,
I have a question for you : I have 3 monitor speakers, when I change the volume from MIX
it’s ok, and it doesn’t change the LR volume, but, if I change LR volume, change the monitor’s volume as well!
How can I make them indipendent from LR?
Please help me!
Thank you in advance!
Mirko.
Sounds like you’ve got a routing problem or you’re not where you think you are as to which bus you’re working on.
Things to check:
  1. Pre/post assignments on Mix buses.
  2. Control group or DCA assignmnts.
  3. Bus channel assignments.
ok, I’ll check.
Thanks a lot!
Mh…Now I’m thinking that I keep always the monitor’s pre off…
Tomorrow I’ll try to turn on it.
Maybe the problem is that.
Thanks in advance!
Monitors should be prefaced, sounds like they are post fade
