Mix master level to follow LR level
Hi all,
I’m not sure if this has been asked before and I have had a read through the manual a few times and nothing is glaring out at me! So I’m after a little knowledge.
I run my subs on an aux mix, usually mix 9-10 so I have a bit more control over what I am sending to subs and can quickly adjust on the fly. Each channel is sent post fader to Mix 9-10 so I can mix from the LR layer. Is there a way of getting the master of mix 9-10 to follow the master of LR?
It’s a bit of a curiosity more than anything to see if it is possible, but I haven’t had the chance to have a play at a gig!
Cheers
Assign the main LR master and the mix 9-10 master to a DCA and the use the DCA the overall mix level master fader. You can set the level balance as you like on the mix 9-10 and main LR master, adjust the assigned DCA will track those settings.
Thanks Mike, I’ll give that a go!
