Wonder if someone could direct me to the Mix Rack IP address. I believe the IP between the surface and the mix rack was lost. I just can not find the IP on the rack. Thank you all in advance. This morning I lost the connection to the mix rack, so non of my controls came up. I get a screen that asks me to connect to the mix rack.
Try to reset the network on mixrack.
you will fins descrition in manual or google it.
I will look into that. ??
If you didn’t changed network settings default IP is 192.168.1.70
You can set it back to the default network settings.
From the “Mixrack Getting Started Guide”
To reset, turn the MixRack off, insert a pointed object to press and hold the switch whilst
turning the MixRack back on. Hold the switch in for at least 20 seconds.
