Mix Select by Soft-Rotary
Wouldn’t it make sense to add a soft-rotary option “Mix Select” to the SQ-Rack?
Touching the upper right corner of the main LCD in order to select the active mix often isn’t reliable so I would prefer an option to scroll through available mixes with a soft-rotary and then activate the send mode for that mix with the corresponding soft-key below that rotary.
