Hello everybody. Newbie question: I want multiple mix sends to send channel signal post channel fader with only moving the fader and not having to select different mixes. In other words I want channel signal to increase or decrease simultaneously through multiple mixes when I adjust that channel’s fader. Is there a way to do this?
Assuming you have a 16, 24 or 32:
Method 1 - See page 27
Select Mix 1.
Hold down “Pre Fade” key.
The “Select Key” on each channel shows green if the mix is pre fade - press each select key and the green goes out - You now have that mix running post fade.
Set each channel fader to 0dB (or other level if required).
Repeat for other mixes.
Method 2 - See page 38
Select Mix 1.
Select the Master fader for Mix 1.
Press “Routing”.
Select “Mix Sends” from screen.
You now have a “Pre” or “Post” button on screen for all channels on each mix. Use this to select “Post”.
As before, set each channel fader to 0dB (or other level if required) for each mix.
