The organisation of the Mixes (auxiliaries) in the SQ is an advanced function of the famous “flip to fader” option found on the previous consoles like X32, M32 & so on.
This option is very useful when you have only or mainly inputs in your channel banks. However, with the ability to choose what you want where you want it, the “flip to fader” function becomes a bit complex.
Indeed, we often use one or two layers for the mix where we find some inputs, sub-groups or DCA, Fx, Matrix… If I flip to a mix to adjust a send I don’t have visually all the inputs assigned to this mix. It is also confusing to see some output channels, matrix etc that are not assigned in this mix when I select a specific Mix ouput.
Would it be possible for those who manage monitors from FOH to have a kind of Mix Spill: when I select a mix I would like to see only the inputs assigned to this mix.
Advantages :
- faster access to sends
- Clearer to see the channels assigned to that mix
- Avoid forgetting that you have selected a mix rather than the L/R
- More clarity for a second user
Thank you in advance for your consideration.
