Mixing Station for CQ now available
Just downloaded this, very interesting.
Cost £5.99 but most probably worth it:)
Tks for sharing the info.
Custom layouts. IDCA. Niiice!
Cool!
I do prefer QU-mix to this but it’s good to have. Hopefully the CQ app will have same status after some tweaks!
Maybe if someone gets a nice layout with mute group buttons, tap tempo etc, they’d be kind enough to upload it? I don’t have the patience or skill to ever get Mixing Station the way I want it!?
Have not used the app before but just downloaded and paid. The DCA function, DCA spill, and custom layouts looks like it will make mixing much faster. The built in midi support will allow something like an X-Touch control surface to control the CQ via an iPad or laptop. Pretty slick.
Only if I am missing something, I can’t get DCA or mute group to work…
@willmodelisme
No expert on MS but this is how I got DCA working:
In settings/layer hit the “+” to add a new layer.
It’ll show a screen where you add what you want channel wise.
On that same page hit the “+” again and add IDCA.
Then you’ll have a screen to add the channels you want on that IDCA.
If you hit the IDCA button on the top of that screen you’ll be able to rename it.
Skip back now to main mixer view and select your new layer on the right hand side where you see “Fine, Mix, FX send” etc.
Now you’ll find the IDCA slider and it’ll be linked to the channel selection.
If you touch the top of the IDCA tab you’ll bring up the allocation page again where you can edit your selection!
Hope that helps!
Haven’t set up mute groups yet!
Sorry just to clarify, to edit your DCA selection:
IDCA tab at the top of the IDCA fader
Had no success getting mute groups working, got a quick reply from a he developer saying “CQ has no mute groups, use IDCA as a workaround”.
I know what he means. Must see if I can add stand alone mute buttons for this purpose.
I should have asked about media play/rec controls as I don’t see them on this first version either or have I missed it??
Yep, work just fine, many tks.
Trim for USB is not present also.
Yes, I cannot see any possibilities to add media player controls also.
Note that the color for OUT and MAIN can be edited now.
I was able to create custom “mute groups” by creating a button then assigning multiple instances of channels, then channel mute (mute inverted).
This allowed me to create FX mute, monitor mute and vocal mutes.
It’s very flexible but because of that it’s a bit fiddly.
Apologies to Keith @ A&H - I hope you don’t mind me posting about MS here!?
Got it working pretty sweet now - used it for a livestream tonight.
Quite a difference having 95% of what I need on the one page!
BTW - uploaded a couple of my layouts to the MS website, they might be a handy starting point for someone? Feel free to improve them please!!?
Having taken a few hours trying to figure out MS’s idiosyncrasies I’m definitely understanding and liking it a lot more than I did.
@robbocurry
I too have been playing around with MS and trying to set up a standard scene that I would use, like you say, you have 90+ % of everything on the one page, but for me it is just a case of getting used to the way that it looks and works and to build up some muscle memory. I will take another look today at MS and see about setting up some mute groups that @BigMerv has mentioned about being doable.
I don’t think that there are any controls yet for USB playback on MS, that is something I do need at every show as the band has a play on & play off. So having to switch between apps would be a pain.
@BigMerv
No need to apologise!
Compared to MixPad, Mixing Station is a far more ‘tweaky’ app, which we know some people prefer.
The only thing I must note is, being built and tested by a third party, Mixing Station is not supported by A&H and is used at your own risk.
Cheers,
@KeithJ A&H
Glad you’re not blacklisting me???
I’m old and set in my ways so MS is a stop gap until you launch “CQ-Mix Classic Version”, child of QU-Mix???.
And yes, I would definitely pay for it!
@BigMerv - I assure you that having Mixing Station support will help sell CQ consoles for A&H! It’s nothing but a positive thing for A&H and I have to assume the powers at A&H understand this.
Silly question,
Does the midi work ? Can we control the mixing station of cq with a xtouch fi ?
