When using Mixpad 1.5 Windows 10 to configure/setup SQ-7, when changing io/patch for a channel from a local assignment to a USB assignment, the strip still shows the local assignment. I have not tested this on the mixer when recalling the scene from the saved scene (flash drive) to see if the patch does change to USB (as assigned in the io/patch) or if it stays as indicated on the strip. Display issue or bug?
It just works on my version…
Update - just tested with the mixer. The file is accurate when loaded in the mixer - so the issue is the strip’s display, not the file.
@SoundGuy -
Please could you clarify where you’re looking (which strip display?) and the steps you took so we can figure out if there’s an issue here.
Thanks ![]()
@SoundGuy -
Thanks for the images, there are two ways to understand what you see as the issue though -
‘Ip1’ refers to input channel 1, which is one of the 48 input channels in the core of the mixer rather than local input socket 1. Once you rename one of the input channels, you will see Ip appear in the naming section to help keep track of things.
If instead you have patched USB input socket 1 to Input channel 1 before the first picture of the processing screen, and are still seeing the preamp controls, then I’m stumped! I cannot reproduce that behaviour here, so please could you send us a copy of your show folder using https://support.allen-heath.com (and then clicking ‘Submit a Request’) so we can look into this.
Thanks for your reply Keith - I now understand what I’m looking at. I interpreted the Ip1 as the source, not the input channel, so now it makes sense. Also looking at the Socket Preamp settings visibility makes sense, and now I can move forward with confidence. I would like to see (maybe as a future product update?) in the top right of the channel label something like L1 (local) or U1 (USB) or some other designator to reflect the actual patched source. Just my .02 cents. Thanks again.
