As the title says: is MixPad 2.1 downward compatible with firmware 2.0 and is there still a firmware 1.9 compatibility mode?
the app description says:
Tis version of MixPad can connect to a dLive mixing system running:
- dLive Firmware v2.00 or subsequent v2.0x maintenance releases
hence my question, as the app text seems not to be suitable for this version.
No.
Sometimes it is silly to write something with more than 20 characters, just to say no.
You tested that?
If true, they should change the app info asap!
NicB
4
dLive MixPad and OneMix have a legacy mode that can be configured before starting the app, in the app settings.
dLive4You should automatically connect to 2.1 or 2.0 without extra configuration.
Thanks a lot for clarification, Nic
