Mixpad mix buttons on left
I’ve been using the SQmixpad app for a couple of shows now and I have one suggestion. I hold the pad with my left hand and I find I keep accidentally touching the mix buttons on the right side with my right hand, changing the active bus. I would like the option to move them to the left side.
A&H probably never develop this feature.
You can create any layout in Mixing Station, I highly recommend that app if you want to customize.
OP is not wrong to ask for the feature change, but there is no question that the best current solution is to use Mixing Station instead of the OEM A&H apps. It can take some time to get use to and wrap your mind around all of the functionality. But once you get a hang for it, you will never use anything else!
