I’ve had a problem with MixPad/Onemix since the day I downloaded it: I can’t control the width of the Parametric EQ bands. I’ve tried the two-finger “pinch” technique and it works maybe one out of 40 times, but it’s very unreliable. Every other parameter works flawlessly. Any ideas?
I know your post was put up a while back, but the reply may still help others.
I found that a vertical pinch works better than the horizontal. Also be sure the dot on the graph is filled in to indicate which frequency you are working with.
Hi KB:
Thanks for your reply. I tried your tip and it worked perfectly! In the 3 1/2 years I’ve had my iLive, I’ve never used Mixpad. I find it quite un-intuitive, and it doesn’t work the way I would expect it to. In the heat of a gig, I can’t get around on it. I’ll have to study the manual and spend some time with it, I guess. I have iLive Editor on my iPad as a virtual desktop and that has all the features I need.
Actually just now I tried adjusting levels (in Demo mode) in two separate Aux Mixes and that doesn’t work either. The Aux 1 levels are mirrored in Aux 2. I’ll see if it works when I’m actually connected to a mixer.
Sorry, I don’t check this forum much anymore.
I would have to check about the aux level thing, but I think the demo mode it doesn’t keep the changes on a per aux basis. I noticed that while I was in a demo mode once too.
I don’t know how many channelsyou are dealing with for a normal set up, but we definitely took advantage of the custom layer layouts. Especially the ones running one mix.
