MixWizard Wz2 repair
Hello, does anyone know of someone in the UK that can service a MixWizard Wz2? One channel is weak and distorted. Every thing else works fine however I’m worried the other channels might also start to go soon as it’s getting quite old.
I would take off the bottom cover and check all the ribbon cable connections.
There is a ribbon cable cable that connects all the channel cards together.
Disconnect and reseat the plugs or even brush a little bit of deoxit on the pins.
Actually before doing that try cleaning the channel insert jacks, 1/4 inch dia. brush with a bit of deoxit on it.
Okay thanks that’s sensible. Given the age I kind of assumed the caps are starting to go but I’ll give it a try. Thanks.
Your best bet for servicing is to reach out to our UK servicing partner, Audio Technica - they’ll be able to direct you to all of their registered service partners.
Audio-Technica Ltd
Technica House
Unit 5
Millennium Way
Leeds
LS11 5AL
Tel: 0113 277 1441
supportuk@audio-technica.eu
https://www.audio-technica.com/en-gb/contact-form
