MMO and Waves card
Hi, i’m from Brasil, and i have a question about ilive system
Can i use a MMO card and a Waves Card in the same system ?
Because i use AVIOM system, and i want use waves plug ins too.
someone know about it ?
thanks
You can, but it takes jumping through a few hoops.
There is one card slot on an iDR rack. So you could use the Waves Card or the MMO card there, but not both. However, if you fit that card with an ACE card, it allows you to connect 2 XDR extenders and each extender has a card slot.
So you’d need an iDR with an ACE card fitted. 2 xDR-16 extenders. Put your MMO card in one and your Waves card in the other.
-d
David Shriver
Director of Technical Operations
Email: david@rockportmusic.org
Shalin Liu Performance Center
37 Main Street
Rockport, MA 01966
Also if you have a modular surface with a RAB2 card you can put the MMO card in the surface port B. In fact its the only card you can put there!
