I know this has been mentioned a handful of times, but Momentary actions would be great.
Use case, Talkbacks. Press and hold to unmute TB channel and mute when released.
I use 3 channels for a single Mic, and unmute depending on which group I need to talk to at that moment. Better than needing 3 mics.
(Yes yes, the talkback section of the console, but that doesn’t allow for different levels per mix, so if the drummer needs me louder and the bass player needs me quieter, so that section is already ruled out).
Alternately, allow TB section to have level adjustment per mix per TB Group.
I want momentary unmutes for delay sends, to just affect words or phrases.
This is possible already…but I gather from your 3 channels, you’re looking to switch between different inputs?
Can you tell me how? Have not seen this in the soft key or actions menu
One TB Mic, Three Channels (IEM Crew, IEM Band, Physical Speakers)
My apologies, I meant the “talk” button can be setup to be momentary.
For your scenario…I can setup a softkey to turn on/off a talkback group, but not turn the talkback on (latch or momentary). I think you still have to hit the talk button. Not sure if this is what you’re looking to do?
Thanks Brent,
Looking for a momentary mute or unmute of a channel or mute group.
The latching feature of these already exists, but not momentary
