Monitor mix window request
Hi Allan and Heath Team,
After using my CQ20B at a show this weekend we have found it would be far easier to have a sends mix window. That way if there is any requirement to adjust a performer’s monitoring mix you can just select the send and mix the individual instruments sends that way. I find it a little counter intuitive to have to select the instrument and then adjusts its level.
Seasoned users: if there is a way to do this that I have missed please let me know?
+1
If you go to the faders tab then select your outputs window on the right, you will be bale to pull up a fader window for each output. I hope this is what your are looking for.
FADER button / Sends to (to right) /Select the OUT you need to modify / modify the individual fader you want.
To go back to normal, clic again on Sends to / Choose Main LR.
Please add a new version of the iPad app (CQ20B) that emulates the SQ 5 layout with mix sends in their own full window.
thank you
“FADER button / Sends to (to right) /Select the OUT you need to modify / modify the individual fader you want.
To go back to normal, clic again on Sends to / Choose Main LR.”
was exaclty what i was looking for :slight_smile:
I’m going te reply here as well…
I already posted a request to make the ‘sends to’ mix tabs more easily available. Now you have to press the small ‘sends to’ icon on the screen.
I would love to have the ability to assign the differend ‘send to’ mixer tabs to the soft keys, of to be able to scroll through the differend screens by tapping the Fader button multiple times. (press home and Fader to start at the default fader screen)
Hope this makes sense…
