Setting up SQ7 for a band. Band will use SQ4U to access 8 in ear mixes via mixes 1-8. I need an additional couple of wedge mixes for singers. I’m not seeing a way to make the Groups a pre-fader send or switch a couple of fx sends to pre-fade. Any suggestions?
Aaaaand I found where to make the effect sends pre-fade.
Correct me if I’m wrong, but when you say ‘the groups’, it sounds like you assume that you must use those groups for additional monitoring, but you can easily change those groups into extra mixes, just like mix 1-8. You can do this by going to ‘mixer configuration’ in the setup menu, and selection the number of aux mixes you want. 8 aux mixes means 4 groups, 10 aux mixes means 2 groups, etc.
Thanks Chris!!! I missed that page.
