Monitor problem
Hello guys
Can anyone help me?
I’m using a qu-24 in my church
This one started to do somekind of link with my mix’s.
If i turn on mix 2 mix 5 also show up
If i send drum and guitar in 2 it also goes in 5.
If i mute mix 2 mix 5 is also muted.
I dont wanna do a factory reset.
Ok, first try the opposite way:
What happens when you send something to Mix5?
  • does it occur on Mix2 as well?
  • does it occur on Mix5 as expected?
  • does this only happen between Mix2&5?
    Since Mix5 is normally named Mix5/6 (since it is stereo), are we talking about a stage monitor which is expected to be connected to Mix5 but actually chained with Mix2?
    Are you connecting the monitors through a stagebox? Maybe both output sockets are assigned to Mix2 (so sending to Mix5 does nothing or occurs on another monitor)?
Guess we need much more information on your setup.
My Qu-Pac started doing the same thing recently. I did a hard reset and it’s still doing it. I’m using the 1st 4 mono mixes (1 thru 4 for each 4 performer’s iem’s) and no matter which mix I change in Qu-You, it mirror’s itself in all 4 mixes. So performers no longer get individual mixes. Everyone is forced to listen to the same mix.
I’m using v1.91 and I adjust each performer’s mix on the Qu-You from my iPad Pro. It used to work fine, but we had a guest Sound guy who was fiddling with routing and I couldn’t get it to work at our last gig. I was certain that a hard reset would fix it, but it did not.
Any help would be greatly appreciated. We’ve got another gig in 7 days.
Check your routing…
Check your tap points (I.e are they all prefade?)
Hi Bob,
Thank you for your quick response. I don’t know what a “tap point” is, but I checked the “Mix send settings” and all the mixes (mix1 thru mix4) are set to “pre-fade” and “assigned” to “all on.”
Also, I’m a newbie and don’t understand “routing” very well and that is the reason that I chose to do a “hard reset.” I suspected that routing was fiddled with and the manual said that the “hard reset” would set all the routing back to defaults. I’m wondering exactly what specific “routing” that I would need to set?
Any help is appreciated.
