I’ve seen the motion tablets mentioned on the forum here a couple of times, and I’ve found an LE1600 at a good price, but as this is an older model I’m worried it won’t do the job with Editor - anyone able to advise me on this???
I think you need a dual core processor, I believe the factory recommend this as a minimum my own experience would certainly bear this out. I ended up with a Lenovo, X60 it was a corporate re-furbished model running Vista which I do not like. However it was quite cheap. Seems fine, I use it for Editor, Lake and Smaart 6. Screen is a little small possibly, but OK.
That’s what I’m thinking, I was just wondering as the 1.5ghz processor seemed ok compared to some other stuff, but I’m not a spec nerd so I wasn’t sure! I’ll keep an eye out for something with a bit more power then, refurbished/ex-lease stuff seems the way to go.
I’m actually not worried if the only thing it runs is editor, it’s going to be a dedicated thing anyway & I’ve got other machines for the rest of the gig duties!
Mine came with duo2 core, 2.5GB ram & 30GB Hard disk.
I used it with ilive editor last Friday night for the first time. I mixed on IDR32.
There were some moments of “system busy” window popping up when jumping from one channel to another channel “SEL”.
I don’t know if this is a laptop hardware issue, wireless issue, or windows 7 64 bit issue. Maybe it is a simply JAVA programming issue. I’ll never know.
Ilive editor doesn’t work as fast as YAMAHA SM as far as I can compare. I operated a LS9 for a year from the same tablet PC and never had that kinda lagging. I’m on the same wireless network. I got rid of LS9, so I have to learn how to live with that until I can afford a T80 or T112.
