Moving between templates
Does anyone know if it is possible to move between templates without changing the settings?
For example - One operator has started fresh using the “All Quick” template. They get most of the way through setting up, but someone adds a lapel mic and I need parametric EQ.
I can’t see a way of changing from the dumbed down Easy EQ, to the full parametric EQ without completely resetting the desk and starting everything from scratch.
Am i missing something?
Our clients often move between experienced and inexperienced operators. I can see the purpose in the simple set up templates but when an inexperienced operator asks for help we should be able to get into the full features of the console without resetting everything?
I hope I am just missing something.
You can convert any Quick Channel to a Complete Channel at any time as shown here - https://youtu.be/luXvPADhuy0?si=qQUkFwV2Ww8s6-x1&t=55
Just note that it can’t work the other way!
Cheers,
