Please can we have the soft keys do more than one thing? For example, I’d like to define a single “Home” soft key which simultaneously…
Puts Bank 1 to Layer A (not currently possible at all on a soft key?)
Puts Bank 2 to Layer A (ditto)
Clears SELection
Clears Mix (i.e. returns to Main L/R)
Clears PAFL
I might also configure a “Panic” button which mutes all auditorium outputs (Aux 1-4 + Main L/R in my case, leaving Matrix outputs + other auxes on because they go to recording equipment, other rooms, induction loop, etc.).
While on the topic of softkeys how about being able to label them so you can tell what they are from the iPad app.
I would like to have full control of USB audio via a tab on the app like the buttons to switch between processing and routing and setup just add a button for USB audio. But if not to set softkeys to control USB playback if a control tab isn’t going to happen on the app.
