Multi Select Inputs
Sometimes it is necessary to select all inputs at the same time in order to set them up, for example. This is necessary, for example, if multitrack recordings are to be played.
It would be very helpful if, for example, you could select all inputs at the same time by pressing and holding the “Multi select” button in the “CONFIG” and “INPUTS” area. Then it would be very quickly possible to set all inputs in the “Input Source” menu to either “Analog” or “USB”.
Another possibility would be to be able to program the softkeys in order to assign the function “select all inputs” or “switch” to these softkeys.
In my opinion, however, the “Press and Hold” of the “Multi Select” button would be the better option
+1
(Or a quick double tab)
