Multicast Filter
Hi there.
I’m using Linksys WRT160Nl router to connect to my IDR32. There’s an option called “Multicast filter”. Does anybody knows should it be switched on or off to use multicast mode without problem? I didn’t understand it from Linksys help. Thanks to everybody.
When you enable “Filter Multicast” in your Linksys router, you are telling your router to remove, or “filter out” multicast traffic. What I don’t know specifically for your Linksys router’s firmware is if “Filter Multicast” affects just the wifi, or just the LAN ports, or both wifi and LAN. You’ll have to find this out. My -guess- is the filter is just for wifi. Hope this helps.
