I just noticed a UI bug in the MultiDB3 FX. The bug appears on the mixer as well as any SQ app.
Band 3 shows the wrong input level (see below for the details).
Here are two screenshots:
- First one with a 8kHz@0dB sine, as you can see it shows no level
- Second one with 1.5kHz@0dB sine, it shows a level (which is wrong).
Details:
- The gain reduction metering offset for the HF band is at index 3 (NOT 2 as one would expect)
- The input level is also at offset 3 in the data model of the mixer, however the UI uses index 2 for this.
- This means that the HF level meter shows the “HM” band which is not available on the MultiDB3
