Hey all, wondering if there any plans to enable more than one Insert on a single Input? If I wanted to insert a De-Esser and a Flanger on just the lead vocal, setting one as an Insert and then the second as an Insert as well cancels out the first FX Insert… Vocal chains in a live setting can get complicated and require multiple inserts… any work around suggestions or is there an update coming?
Certainly no one here can or will answer that.
But you asked for a suggestion:
If you really need 2 inserts in a row, you can send this channel to a group and create the second insert there.
And: In my opinion a flanger is actually more of an FX channel and not an insert.
This makes it much easier to dose and change.
