I use my QU-32 mainly in my studio for recording. Now I want to add a second pair of monitors to my setup. Does anyone have a good strategy for doing that? I want to easily switch back and forth between the two monitor pairs. Amy ideas anyone?
I use a QU-16 for the same purpose, and have a HOSA SLW-333 AUDIO SWITCHER, which is fed from the QU Main Outputs. It has a Stereo In and 3 Stereo Outs, so you can have 3 Monitor sets and switch between them. I have a purpose built long long cable which feeds a set of monitors in a different room. It’s a good setup. Hope this helps you.
I was hoping that I could use the QU-32 itself for this, but I suppose I have to resign to buying more gear… Always fun but don’t tell my wife. Thanks anyway!
@NZdave Hi, can you set that matrix output also to MONO (for one mono reference monitor)?
thanks!
3 Possibilities I guess: alt-out, AES out, (stereo) mix out ?
Good luck !
Giga
@xiim There’s no provision for mono [monitors] into any monitors.
There is no Tab or switch anywhere from memory.
You could get a summing adaptor for a seperate single monitor.
Hope this helps
