So here is my deal. I have a sub array flown. I also have a few boxes on the floor. I am using the LRSub config. I can assign multiple outputs to the sub bus no problem. The issue is my floor boxes are a few feet behind the flown boxes. Anyone have a thought on how I can delay the other line separately? Right now the only delay option I can find is on the Sub mix itself and not on the outputs so any delay would affect all the boxes. The tops are no problem as they are a separate bus than the subs obviously.
Don’t have a mixer in front of me - is it possible to send SUB out to matrix?
ddff
Yes and looks like it should work well. From the block diagram it looks like a matrix fed from a main/aux is taken pre-delay and selectable pre/post fader. So the Main/Sub feeds would have their delays and the other subs would have their own delay on the matrix feed. It might be in the Manual but I couldn’t find it and am going by the block diagram. Please correct me if I’m seeing this wrong!
