Multitrack files from eg.Telefunken site?
Hi!
Multitrack file playback without DAW?
I have been trying to open multitrack files from the Telefunken site but I can not open them in my SQ-5.
I have tried both 48 and 96khz multitracks
I have been following the advice on file names, sizes and folders on the USB drive, but have not had any luck.
I can make a multitrack recording on the SQ itself, and I do not have any problems with the SQ accepting my USB drives.
I have been told to open the tracks in a DAW and drop them into tracks created in an SQ recording, but I would like to know if anyone has been able to open downloaded multitracks directly downloaded to a USB drive just using a computer for downloading and moving/renaming files (without a DAW that is…)
Lars
Hi Lars,
Here is a knowledgebase article with more details on what’s required regarding the format/naming/folder structure here-
It does all need to be exactly the same as it would be if the SQ had made the recording in order to ‘trick’ the SQ into playing it back.
i.e. it’s not only a case of renaming and organising the files, they need to all be exactly the same length as well as the correct format (mono 48/96kHz 24bit WAV with minimal meta info).
Hope this helps!
Thanks Keith!
I have looked carefully at the SQ-Re-Rendering… page many times.
I have renamed all files (exactly the same size, length, sample rate) and put them in the specified file structure, still no luck. I put several hours into renaming and organizing many different Telefunken multitracks, but no go… Could it be a metadata problem then?
I recorded a multitrack using my SQ5 and looked at the file naming and structure to get it right… The strange thing is that if i record an empty multitrack in my SQ, I get 22 tracks. 19 of them are the same size (in this case 2,4mb) but there are two 66kb tracks and one 33kb track.
Has anyone found a multitrack that I can open in my SQ without learning to work a DAW?
I had a lot of issues too, but discovered that my audio file converters were quietly putting headers in the WAV files.
I was finally able to convert them using Audacity which is free. I had purchased 2 other paid converters and neither of those worked, and I didn’t want to use another paid option.
In Audacity;
Set Sample Rate (48k or 96k)
“Import” the original track(s).
Export / or Export Multiple
Choose “WAV (Microsoft) signed 24-bit PCM”
“Remove” Metadata tags when prompted
Name Tracks to SQ format
Once you get a good save, create a template in Audacity for to speed things up on your next run.
Hi Lars,
Yes - the re-rendering using a DAW with the settings shown in the article ensures the file type and size but also notice that the options for embedding BWF, Tempo and Markers are deselected. There are some programs which will strip data (e.g. tag stripper for mac - https://www.markvapps.com/tagstripper or you could do it manually using audacity - https://www.audacityteam.org/) but this still doesn't guarantee compatibility which is why we suggest using something like Reaper that can do everything in one go.
This doesn't sound right, so it might be that your USB storage is not suitable for multitrack. The meter and error logging on the SQ-Drive multitrack screen will give the best indication of performance. Note that we recommend using an external caddy type drive for multitrack rather than a USB stick/pen drive.
Can that be SSD or SATA or anything else?
Anything else I need to look out for?
Can you recommend one?
Thanks, Bob
@SpicerBob
We don’t officially recommend any drives as chipsets (and therefore performance and compatibility) can change in products without notice, either over time or from region to region.
This is related to the caddy and connection to the mixer rather than the drive itself - I’ve not seen any problems relating to the SSD or HDD itself.
We just don’t recommend pen/stick drives for multitrack as the majority of them are spec’d for bursts of data transfer rather than the continuous speeds needed for recording/playback.
Another option is to use SD cards with adaptors as described here - https://support.allen-heath.com/hc/en-gb/articles/4403616227985-General-Qu-SQ-SD-card-adaptors-for-Qu-Drive-and-SQ-Drive
SD cards performance is more regulated and so once a suitable adaptor is found, it’s just a case of getting SD cards at the correct spec.
Cheers,
