We’ve recently started running our guitar player’s Helix output into ST1 instead of just a single mono channel. But when we record in multitrack, ST1 doesn’t record.
Is there a way to tell QU16 to also record ST1?
IOPatch → USB-Audio You can patch 18 channels, so f.i. Use 17 + 18 which are main L and R for St 1.
Good luck !
Giga
I sounds like your recording multitrack to the QU Drive using a USB stick or are you using the USB B connector on the back to connect to a DAW something on a laptop.
Follow Giga’s advice if using the QU Drive.
Wow, thanks you guys!
Yes, I’m recording to a USB stick. I’ll try Giga’s method.
Thank you!
