Bonjour,
Avec mon groupe je veux enregistrer en multipistes les pistes numéro 1 à 12. Quand je copie ma session sur le pc, j’ai les pistes de 1 à 18 sur ma clef usb.
Comment enregistrer seulement les pistes 1 à 12 sur ma clef ?
@Babastone
you said:
Hello, With my band I want to multitrack tracks number 1 to 12. When I copy my session to the pc, I have tracks 1 to 18 on my usb key. How do I record only tracks 1 to 12 on my key?
Do not assign any tracks to 13++ and you will only get 1-12 although you may see others that are empty.
Be sure you do assign 1-12 !
Voici comment je fais. il y a t’il une mauvaise manipulation de ma part? Car j’ai 18 pistes enregistré à chaque fois.
je ne parle pas français
veuillez utiliser l’anglais pour que les autres puissent comprendre et aider aussi
veuillez utiliser google translate si vous avez besoin d’aide
vous obtenez toujours 18 canaux
les vôtres ont entre 1 et 12 ans
ignorer 13-18
Here’s how I do it. Is there any mishandling on my part? Because I have 18 tracks recorded each time.
Visit the technical support page at: https://www.allen-heath.com/support where you can check the Knowledge Base
or
submit a ticket to the Support team.
QU Drive will always record 18 tracks regardless if anything is actually using those channels, so in your case you will have tracks 1-12 containing data but although tracks 13-18 will still show up, they won’t contain any data.
So you’re doing nothing wrong and there isn’t anything wrong with your desk.
@Lee7
he didnt get it when I told him that in his French
ignorer 13-18
Maybe you can convince him this time
Hello I am working with Qu-Sb and do sometimes multitrack recording.
Qu Drive allows to record 18 tracks but these tracks are 16 + 17/18 that correspond to the LR, right?
If I assign in the I/O patch USB my ST in 1 to the track 17/18, I don’t have my ST in 1 in my multitrack files…
Is there a tip to really record 18 TRACKS WITHOUT THE LR ?
It’s really important for me to do so. With my band we use the 16 XLR inputs + the ST in 1 in live and rehearsals…
Thank you.
You can patch any Input Channel Insert Send or Direct Out, any Mix out or even PAFL to any USB channels.
This ‘USB Audio’ output patching is shared by Qu-Drive and USB-B (with more USB channels available on USB-B).
To change the patching in Qu-Pad:
- Go to the 'IO Patch > USB Audio' screen
<li>Choose the 'CH/ST/grp source' - this is either Insert Sends or Direct Outs, the second of which takes signal from the source point in the channel set in the 'Direct Out Global Settings', which itself is accessed by touching the little arrow in the 'Processing > Preamp' screen when viewing any input channel.</li>
<li>Now simply touch in the patching matrix to patch any of the Qu channels at the top to any of the USB Audio channels on the left</li>
Hope this helps!
We go on talking about it here okay? This is your your more detailed answer. Thank you again for your help Keith!
English is not my basic language so I have to translate a little your technical answer.
If I understand well, you advise me to work in “direct outs” mode and to take the source of any track just after the preamp, right? (post preamp to be correct) ?
In this case, I will be able to assign the stereo in 1 from the Qu-Sb to the 17/18 channels of my multitrack recording, that right?
So, I just plug my iphone in the ST in 1.
Then I selected « direct outs » in the I/O usb patch… And I chose « post preamp » in the direct out preamp section of the individual tracks.
Finally I plugged an USB key in the Qu-SB and checked the multitrack Panel with a mic on channel 1.
The result is not what I expected : nothing on 17-18 tracks. But I get the sound of my mic on channel 1 and see the meter of ST in 1 moving in the main inputs panel.
When you play back, your ST1 recording will show up on channels 17/18 (where they were recorded to). Make sure you have channels 17/18 set to receive from usb for playback.
I made everything you suggest Keith but I slowly think something doesn’t work well, especially with the I/O patch…
I explain : if I send in the I/O USB patch the mic source (the mic is plugged in the input 1), to the channel 2 or 3 (even simultaneously, it’s possible), then the mic always appears on channel 1 !!! Due to the routing, it should then appear on channel 2, 3, (…) of my multitrack recording. It’s very strange.
Nothing has an effect on the routing of the tracks in the multitrack recording pannel.
Track 1 is routed to channel 1, 2 on 2, …
It’s like is the I/O usb patch didn’t work.
Just a minute…
When I clic on the rec button (passing the rec mode on “pause”), the channels 17/18 are ok!!!
If record is not armed, then I don’t see the ST in.
Strange but it seems to work!
THANK YOU VERY MUCH KEITH !!!
