Mute issue after app update
I had been using the mixing station to run our QU mixer from my stage and remotely throughout the room. A month ago the app updated and now when I am in “Channel View” I can’t unmute a channel without a long press and scrolling to find the channel and then unmuting it where I used to just be able to do a quick press of the mute button and it would go red to mute. does anyone know how to make it a short press?
I think your post is in the wrong group.
Might ask a mod if it can be moved.
It sounds like the “Mute Enable” option might be disabled - either in Setup App Mixer or on a corresponding function button in your layout.
This is supposed to prevent accidental muting, especially on small screens.
However, you should actually get a message every time you try to mute while “Mute Enable” is disabled.
So I’m unsure if my assumption is correct.
there was another app update and the mute enable notification came up when I tried to mute, which hadn’t before. Then when mute enabled was pressed on the main mixer screen it allowed for the regular muting when I went into the track like you said. thanks!
