Mute on Qu16 = Mute in Logic
i use the QU16 and has made it work with Logic on my Apple computer.
It works quite well!
Only Problem:
i want that the signal of a channel is muted in Logic when i mute it on the Qu16.
otherswise its a mess if i want to just create an mix of all channels.
guess it must me an easy thing in the settings (like the mute button is also “post” and not “pre” or somehting), but i am quite unexpierienced with all of that.
thx a lot
Hi Kabarett,
The Qu series uses the insert point to route audio to the USB B bus by default, so you will need to change this to Direct Out in Setup > IO Patch > USB Audio.
Once this is done, you can select a channel and press the Routing key. On screen, you should now see the Global Direct Out settings where you can enable Follow Mute.
I hope this helps!
Alex
I find this works when the channels are individually muted, but this does not work when you use mute groups
