Mute : Why, basics features
Hello, I’m happy with CQ18T but no solution to assign buton “MUTE ALL” is very problematic ! How Hallen & Heath forgot this ?
Logical should be to add 3 features
  • Mute All intry
  • Mute All Aux output
  • Mute ALL output
    In addition to °Mute main L-R
Please see my response to your other post, here:
You can click the downward facing arrow to the top right of this post in order to expand my reply fully.
Yes, I found the solution via the group “Panic” Mute, on a Youtube video (not H&H)…
This feature should be by default, OTHERWISE YOU HAVE TO PROGRAM IT ON ALL SCENES, AND IF YOU FORGET…
Thanks for thinking about it…
In my opinion, having one button assigned to “Mute All” would limit the versatility for other users. For example if you did not want a Mute All function, you would be limited to two soft keys/buttons.
Another solution is having that feature by default one on button…
Or determine in Preferencies that feature is by default on all new scène or Schow…
Unless your only solution is "Power Off2, a little hard solution…
