I don’t have a baseline to gauge how familiar I am with it, but I can make my way around it fairly well. Here’s the extent to which we use it…our output needs are mono.
6 mics on the drums.
4 Wired Vocal Mics
3 Wireless lapel mics
2 Congregational Mics
1 Bass
1 Acoustic Guitar
1 Input for Electric Guitar or Horn
1 For MONO Keyboard
1 For Backing Tracks
1 For Click
2 inputs USB streaming from the iMac
So…23 sources.
I think what I’m missing is the functionality of layers…are layers synonymous with “pages” whereby I could control inputs 17 through 36 using faders 1-16 ? Thus, the major difference being the convenience of having faders on a one to one basis with all of the inputs?
layers are just a way to share faders amongst the channels in the Qu32
and it seems like mixes are also layers although I did not see the manual state that but they seem to act that way
our analog board had 48 channels and was more than twice as long as the qu is
qu32 has a layer for inputs (bottom yellow lights)
implied layers for mixes
another layer to access other features (top blue lights)
and if you push both layer buttons you get a custom layer which might simplify operation by avoiding some layer switching
You can choose what to put where on each of the 6 layers and you don’t have to use all 16 faders on each layer.
So you may decide to put your vocals & the returns for effects they use in layer 1, the drums with their effects in layer 2, and the rest of the instruments in layer 3. Still 3 layers left for groups, aux masters etc. Now the new firmware gives us DCA spill, I think I’ll probably end up with the vocals & other key channels + all of my DCAs in layer 6, once I start doing gigs again.
Like Mark said any fader on a SQ can be set to be any input channel, output mix, DCA, FX Send, ect. You can even have important channels assigned to the same position in each layer so they are always available.
On the QU32 you have one fully custom layer (the middle layer, push both layer buttons at the same time) that you can set the faders to be any thing you what them to be using the set up menu.
If you use the QU Pad app with in the app you can set three custom layers.
pretty much.
I view SQ as a bigger fancier Qu that does more.
better smaller and cheaper than analog would be now.
Layers are just a way to share fewer faders among many things using them while making the device smaller.
They are one of the ways digital has changed things.
No more analog boards a dozen feet long so everything has its own fader all the time.
