Need help with Cue outs from Ableton through Qu-Pac
Hey, all… I’ve got 2 big questions:
  1. I’m stuck with trying to figure out how to route audio out of Ableton’s Cue Outs to the stereo output 9/10 on the Qu-Pac.
I’ve tried every configuration that I can think of, and I’ve exhausted my internet searches.
Has anybody got this working?
The main outs from Ableton run out of the mac on 17/18 in the usb stream.
I want the cue outs to go out 9/10 on the physical outputs, but the signal doesn’t reach that output.
  1. Also, I want to route some of the sends out stereo outputs 7/8 and 5/6, but I can’t seem to get that working, either, even when using the ‘external audio effect’ within ableton.
Are any of you successfully doing this, and how can I do it, too?
Thank you!!
-dustin.
Ableton or not: You can not route any audio directly to a mix output.
Your DAW sends audio streams which show up on a particular channel. Ensure that input routing is set to USB for that channel.
To feed a particular channel to a Mix, the channel needs to be assigned to that mix first and set channel level accordingly. You may also want to set the mix feed to pre-fader, otherwise the mix level depends on LR fader for that channel.
Same for other Mix outputs.
