I have one question. I have iDR48 and iLive T112. Sometimes during the show for 1-2 second in section net bridge mark change from green to red cross an back to green. Audio is ok and no allerts in event logs. This is normal? This happend 2 times during last show.
This Red cross would indicate that you are sometimes losing control data packets being sent between the surface and mixrack. If you are not experiencing any problems and this only happens sometimes would not worry to much. It just means that you are possibly at the bandwidth limit of control data.
If you experience any control issues this could indicate where the problem is.
Are you running any other IT equipment connected to your system e.g. Laptop, Router, managed switch? If so you may have some processes enabled that are causing lots of traffic on the network resulting in the bandwidth being maxed out.
One thing you could also check is the data agregation between the Mixrack & Surface.
Please navigate the touchscreen display to the Mixrack Preferences - Port A/B setup - under ACE PortA select advanced status. Then let me know what the aggregation RX bytes and RX packets reads for the surface and mixrack? Also how long the system had been running when you took this measurement?
I have now diffrent problem. After boot up on the latest show first channels from A1 to A8 are totally dead. No signal. I have move input channels to diffrent “8” and all input are ok. After this job system is back to my storage place and i have turned it again and this channels from A1 to A8 is good now… What the? Is possible?
Yes yes all thas check. There is no signal input on leds. After few hours the same show file and scene and this channels are working again. Thats is problem with mixrack.
