NET EQ Insert on chanel
Is it possible to insert a NET EQ 9/12 on a chanel and if it’s possible can you tell me how ?
What is NET EQ 9/12?
Are you talking about the NEQ12?
That is not available as an insert, it replaces the graphic EQ models on mixes as an option only.
And it is part of the dPack.
https://www.allen-heath.com/product/avantis-dpack/
Sure it was the NEQ12 my bad, so i can replace the PEQ to the NEQ12 for having this on an chanel ?
Define channel…
You mean input channel? No. It is only available on buses.
Yes on the input chanel sorry, ok so many thanks but it’s really bad on the PEQ for the first point, i c’ant go over 200hz with. have you a solution for this ?
Switch it to full band mode!
Option button on the EQ screen.
i will try so many thanks
