new AB168 audiorack
Just saw the new baby, i write here so the information will be usefull for everybody:
-if using with GLD, can i use one AR2412, one AR84 and the AB168 alltoghether, placed in different places, and choose wich input and out to use? For example, using all 24 inputs from AR2412, 8 from AR84 and 16 fro AB168.
-AB168 have a thru out: this mean i connect with a single cat5 the AR2412 and the AB168, and no matter wich is first?
I mean, i have to place the AB on front stage and the AR2412 on back stage, so my connection will be GLD->AB168->AR241.
-Are the pres the same ad AR stageboxes?
Luca
Nicola posted this in another thread:
https://community.allen-heath.com/wp-content/uploads/2014/06/Qu-and-GLD-supported-dsnake-systems.pdf
Hi Luca,
-AB168 have a thru out: this mean i connect with a single cat5 the AR2412 and the AB168, and no matter wich is first? I mean, i have to place the AB on front stage and the AR2412 on back stage, so my connection will be GLD->AB168->AR241.
No, you have to connect to the AR2412 first, then daisy-chain to the AB168 I’m afraid. This is due to the way channel allocation works on dSNAKE. As I posted on the Infocomm thread:
You can now assign as many as 24 in / 12 out from your main dSNAKE device i.e. the one directly connected to the GLD dSNAKE port, as well as up to 16 in / 8 out from your dSNAKE Expander (an AR84 or AB168 plugged into the Expander port of the main device, be it an AR2412 or AB168), AND up to 8 in / 4 out from the local Surface Expander. The I/O tabs reflect this arrangement.
serious? Stagebox with handle without Neutrik PowerCon on Stage???
Ok, thanks Nicola, i didn’t see you post :slight_smile:
Are the pres the same as AR series?
thanks!
Luca
@Dusenklang
no problem:
https://www.amazon.de/Monacor-AAC-100IEC-Kaltger%C3%A4tekupplung-mit-IEC-LOCK-Verriegelung/dp/B0078N4JUE
