New DIY Midi device
Hello.
Here is another Midi project.
It is a 4 footswitch pedalboard, send Midi message, CC, NRPN, PC or Note.
It is based on an ESP32S3 with embedded LCD screen board.
I feature BLE Midi.
All editable by touchscreen, with function naming and a color picker for customisation.
Auto saved in EEPROM (values maintained when switch OFF).
Lock touchscreen function.
The ESP32S3 module is a Guition-ESP32S3 8M PSRAM 16M, 5 pouces IPS 800*480 (Aliexpress).
You will need 4 SPST momentary footswitch, 2 JST MX 1.25 mm pitch connectors and to build the box for it.
https://www.thingiverse.com/thing:7296921
Awesome stuff! Keep up the good work.
Thank you sic0048.
Little update for the code, mostly very small graphic improvement.
intégration with the CQ is flawless.
Here is an example of what it can do:
Hello.
My 4 footswitch midi got small feature update (trigger/momentary/toggle mode for Midi Note and NRPN specific MUTES for the CQ ) and a major change in the process of initial flashing the board:
-no more Arduino IDE needed, you can flash the board and upload the firmware directly online.
Check here:
