At the moment, I’m using an (old) Roland VM7000 set-up, consisting of 2 Stage boxes (40 Inputs), 2 VM-C7200 boards (Mains/Monitors), and 2 VS-2480’s for direct recording. The whole system works great, but its time to upgrade.
I’m seriously contemplating getting a T-112/IDR48 set-up, and I have a few questions. Ultimately, I’d like to be able to use two surfaces to control the Mixrack, and also do a full Multi-track recording of the show. Is this possible to do with the fixed-format iLives?
To the T-112/IDR48 combo I would need to add a second surface and either IDR0 or IDR 16 Mixrack, but where would the Multi-track split come from?
Thanks for the reply. On the Fixed Format surfaces, there’s no Port B for the Dante card. Would I have to have to have the recording computer located on the stage instead of a FOH? Or would it be possible to run a second “Dante Snake” back to FOH if I wanted to have the recorder PC located there?
Hi Mark,
you can do it either way…if you use the idr16 as a means to get 2 surfaces then you could put it at foh and have the dante card there…iLive is very flexible…
If you have fixed format mixracks (IDR48 + IDR16) then use a Dante card in each Mixracks port B slot to do both the FOH/MON split, recording split and other Dante splits via a Gigabit router. Port A on fixed racks is reserved for a surface connection. You can also bridge the iLive network into the gigabit router for Editor control. Set up correctly this allows the same computer that’s running Editor and Dante controller to also multitrack record with just one cat5 gigabit Ethernet router connection. If the Gigabit router has wifi you can also add additional iLive connections such as iPad/s (Mixpad App) or other computers running Editor.
Thanks for all the advice. So my T112/IDR48 arrived last Friday and I’ve been holed up with this thing the last 3 days setting up mixes and learning the architecture. What an amazing device! I was used to working with (and around) limitations but the iLive seems to have little or none!
One feature I used quite a bit on my old Roland VM7000/Sounddiver setup was the ability to view channel levels post fade. I do several outdoor concert series in the summer with bands I’ve never worked with. If there are 3-4 singers singing together it helps to see their separate post-fade levels to made sure they are all balanced and audible. Is there any way to view post fade channel levels on the iLive?
