On our QU-16 we use Mix 10 for an output to our powered subwoofers. If we bring down the Master LF fader the subwoofer volume on Mix 10 stays the same and the mix is now out of balance. What is the best way to set up the QU-16 so if I turn the entire band down a bit by lowering the master fader that the Mix 10 volume also comes down proportionately? thanks
I believe you have to change Mix10 to post fader or opposite of default. Pre-fader I think. We had the same issue and we had a sound engineer help us with that issue.
DCA with LR + Mix 10.
Giga
QU-16 doesn’t have any DCA’s.
THe Qu-16 does have 4 DCAs. You just have to add them to the custom layer.
So it does, for some reason I thought it was only the bigger channel count mixers that had those.
Glad that’s sorted. I was going to say “but the app does” ![]()
Giga
Giga, thank you. That’s what I will do.
