Newbie question
Is there a way to control the level of one channel across all mixes? I’ve been trying to figure out how to fade out and fade in ST3 so that it is simultaneously happening on LR and Mix1-10 without effecting any of the other channels.
I believe the channel gain woukd effect all mixes.
You just need to set the mixes that ST3 is sending to to post fade, you can set them
on a per channel basis or globally in each mix set.
