Last night I bought a second hand never been out of the box QU-24 off an AV engineer who had bought the QU direct from Audio Technica (UK A&H distributors) via his works account. Purchased for a project that didn’t take off.
As I already have a QU-16 I took along with me my USB pen drive that has stored scenes on and my HDD that has some multi-track recording on from earlier shows in 2015, took these to make sure everything worked as is should. What I found was, the QU-24 played back my entire multi-track recordings fine, but didn’t recognise any of my 60+ scenes on my pen drive.
I would have thought whatever was saved on one console would be seen by another, or will I have to format the pen drive via the QU-24 and then transfer from a back up pen drive all my scenes that I created on my QU-16 for it to be able to see and load them up?
Just to add, also on my pen drive was the latest firmware update (1.82) for the QU-24, that installed as per normal.
I imagine Qu16 shows/scenes are not compatible with a Qu24, Qu 32 or QuPac.
You can save each channel’s processing from the Qu16 to your User Library, then copy those to your USB jump drive and transfer them to the Qu24. I have a feeling for all the other stuff, safes, routing etc. that will need to be done manually.
Scene, Library and Show memories - All Qu mixer memories are compatible. Files created on
one model can be transferred via USB key and loaded on the other. The extra features of the
bigger models will be ignored when their file is loaded on a Qu-16. The extra features of the bigger
models will be reset to factory default when a Qu-16 file is loaded.
That what it is supposed to do, but on this occasion it doesn’t seem to be working out as planned. I will set up the QU-24 and format one of my back up pen drives and then copy over my scenes from another drive and see if that helps. Not the end of the world if it doesn’t as the bigger desk is other shows etc that I have coming up this year and not for use with the band I work with. Although, if my QU-16 ever went down I could fall back on its bigger bro and load up my scenes (hopefully) without too much disruption.
Some of the files were saved on earlier firmware releases whilst others were saved after the latest firmware release. The daft thing is, I downloaded an FX setting that a member on here had created the other day to my pen drive. The QU-24 can read that and load it up, so why it won’t read anything else is beyond me. I will get to the bottom of it.
