No audio to left out output
No audio or metering coming from the left right main buss
Looking at routing the main mix buss for left right is turned up input fader I’m getting nothing to the main fader
All auxs get signal the matrix gets signal
Any help
Bit when
In my view, the most likely scenario is, that the Main LR is not assigned, and the second, that an insert is interrupting the signal path.
And if none of the input signals reach the Main LR, maybe an insert in the Main LR bus.
Actually I didn’t have anything inserted and in the routing seatings the assign all the inputs the left right is turned on. As I’m using the factory foh setting for layout.
Also I have a bug in the 2.01 I don’t have dca spills yeah work and yes it is turned o.ln si could be a bug
I’m
Mixing from matrix anyone I don’t ever really use a left right buss any lot but never had it not get any audio
Have you checked all the DCAs on the board to make sure that there hasn’t been some accidental dodgy assigning been done?
Happens a lot, and has caught out a few other users recently. Might be that the DCA has had any of the Channels/Groups/Matrix/Master assigned to it, and while unmuted, might be set to -INF on the fader.
Unfortunately, as a non-native English speaker, I do not understand your sentence - particularly also regarding the DCA.
In any case, I cannot imagine that your problem is a general bug in version 2.01; otherwise, there would be an overwhelming number of complaints.
