Hi - been running a particular setup for years with no problems. This weekend I set up for one band and noticed no signal from one of the drum overhead mics… tested mic and cable no issue. So when I got it home I had a look at the channel itself.
I found that there is no input signal registering until I hit exactly 45db of input gain. 44db nothing….
So I thought there might be a GATE being applied or something - but checked and nothing.
I loaded a default “untouched” setup to see if same problem and ran a noise signal down the channel of a known level. Again nothing until it hits 45db - at which point it registers a signal.
Anyone encountered this sort of behaviour before? Interestingly when running the noise tests, Ch4 also reported odd levels whereas 1,2, and 5 beyond all ok … plus bank B1-8 are fine….
Does it need to be serviced? If I backed up the show file and scenes would it be worth trying a hard reset (if indeed that is possible?).
Thanks for any ideas, Ric
